Checklist: SAP Interface does not work
Time estimate:  30 minutes
  2. SAP Interface module is licensed in zenon computers.
  3. You can find all license details of zenon Software Platform products in License Manager (in zenon Startup Tool > Tools).
  4. Connection to the SAP Server is possible from zenon computers. SAP Server is not offline.
  5. Ping commands between zenon computer and SAP Server are successful in both directions using computers IP/hostname/FQDN.
  6. Output of the 'Test connection' in Engineering Studio is:
    1. 'Connection test successful'.
    2. 'Connection test failed:' + text message received from the SAP system.
    Normally the text message is quite helpful, like "name or password incorrect".
    1. No result at all: Check if SAP GUI is installed.
    When SAP GUI is not installed, there will not be shown any error message.
  7. SAP GUI uses the CPU same architecture of zenon.
  8. Typically, SAP GUI is 32bit version only, so that zenon components (Engineering Studio/Service Engine) must use the CPU same architecture.
  9. It is possible to access SAP Server using SAP GUI. In case, in Engineering Studio fails, but from SAP GUI is possible, contact SAP administrator.
  10. Searched and followed error instructions in LOGs related with the zenon components (Engineering Studio/Service Engine).
  11. All zenon components write in the background messages to joint log file(s) saved in '%programdata%\COPA-DATA\LOG' folder.
  12. In case a valid connection can be established to SAP Server, but Remote Function Call (RFC) still does not work.
    1. [Service Engine] [Engineering Studio] Check the 'error description' or the CEL. Normally, these are useful (e.g. function not remote enabled, insufficient user rights, etc.).
    2. Test the RFC in the SAP GUI.
    3. Check the RFC parameters in Engineering Studio:
      1. Variables are assigned to parameters. If no assignment, zenon default value '0' may cause RFC not providing the expected result.
      2. Check parameter datatypes as not all SAP data types are supported by zenon.
      3. If other RFC work, this indicate that the problem is limited to a specific RFC.
  13. Maintenance reports do not work.
    1. Check error messages in the CEL in Service Engine.
    2. Check on the SAP system whether the necessary RFCs are remote enabled.
    3. Check the access rights of the user for the RFCs.
    4. Check the Resource Label of the variable in question. It has to contain a valid equipment of technical location.
  14. Measurement readings do not work.
    2. Check the Resource Label of the variable in question. It has to contain a valid measurement point ID.
  15. Searched in Knowledge Base if a previous issue has been addressed.
