Checklist: Process Gateway cannot start
Time estimate: 30 minutes
  2. Service Engine (zenrt32.exe) is started in the same user context of Process Gateway(s) (zenProcGateway.exe).
  3. The list of running processes in a computer is also included in SIC in 'System Info > Processes' node.
    Some performance counters and process details are also collected.
  4. Searched and followed error instructions in LOGs related with the respective Process Gateway (zenProcGateway.exe) instance and Service Engine (zenrt32.exe).
  5. All zenon components write in the background messages to joint log file(s) saved in '%programdata%\COPA-DATA\LOG' folder.
  6. Process Gateway protocol-module is licensed.
  7. You can find all license details of zenon Software Platform products in License Manager (in zenon Startup Tool > Tools).
  8. zenon VBA and API Events handling are enabled.
  9. You can turn on VBA and API events handling in zenon6.ini file (path: %CD_SYSTEM%):
    [VBA]
    EIN=1
    EVENT=1
  10. Process Gateway configuration files INI+XML(*) are:
    1. ...saved in %CD_SYSTEM% folder.
    2. …syntax is correct as per Process Gateway documentation.
    3. …can be loaded by zenProcGateway.exe using the parameters '/ini:"[FileName.ini]"'.
    The configuration of the Process Gateway may be saved in an additional XML file, depending on the protocol used.
    Process Gateway XML file(s) are not included in SIC report.
  11. Process Gateway documentation have been consulted.
  12. Searched in Knowledge Base if a previous issue has been addressed.
Ethernet connections:
  1. There are no other applications using the same Listening port [PORT] as configured in Process Gateway.
  2. You can use the command (run Command Prompt as administrator) 'netstat -a -b | findstr :[PORT]' to know the applications listening or connected to a specific [PORT].
Windows Resource Monitor shows live CPU, Memory, Disk and Network information about running processes in an user friendly interface.
Processes with network activity are listed and can be filtered for best visualization.
Some of the most relevant information displayed in Network is the active TCP connections (remote/local port and address) and Firewall status.
Serial connections:
  1. Local Serial Port is configured correctly and it is not used by other software.
  2. Go to Device Manager and open the properties of the Serial COM Port used. In the Details tab, select the property 'Service' and copy its value.
    In Windows Resources Monitor, in CPU tab, in Associated Handles window search for the Service value. If it is returned an empty list, there is no application using the COM port.
