Checklist: Smart Client does not work
Time estimate: 20 minutes
  2. Smart Client was installed successfully.
  3. Installation logs can be found in different locations in the %TEMP% or other folder depending of the product version and the pre-requisite.
    You can use a search file application to find specific text in multiple files simultaneously.
    Most common keywords when looking for erroneous messages are: exit, error, failed, code, etc..
  4. zenon Administration Service (zenAdminSrv.exe) is running as a service.
  5. Smart Client ran and was closed correctly before.
  6. Smart Client is registered as ‘Standard’ in zenon Startup Tool.
  7. Smart Client has the same or higher version of Service Engine Server.
  8. Searched and followed error instructions in LOGs related with npzenWebCli.dll.
  9. All zenon components write in the background messages to joint log file(s) saved in '%programdata%\COPA-DATA\LOG' folder.
  10. Smart Client Starter: When starting via a command line or a link with arguments, the command syntax is respected (arguments are case sensitive).
    1. Rules for project and computer name and name of the 'init' function do not have the characters: [space] & : = ;
    2. Period (.) , hyphen (-) and underscore (_) are permitted if they are not at the start of the name
  11. Consulted documentation topic Smart Server > Smart Server, Smart Server Pro and Smart Server Pro Light > Error handling.
  12. In case Smart Client closes unexpectedly, disabled zenon API, re-registered zenon and restarted Smart Client.
  13. zenon API can be switched off by editing the respective sections in zenon configuration file (zenon6.ini) located in %CD_SYSTEM% folder:
    [VBA] [VSTA] [ADDINS]
    EIN=0 ON=0 ON=0
  14. If applicable, in case when executing a VBA macro an exception is thrown deactivate the option "Enable memory protection to help mitigate online attacks in Internet Explorer (Tools > Internet Options > Advanced).
  15. If VBA/VSTA/ADDIN macros cannot be executed, make sure the corresponding entries are set in zenon6.ini file.
  16. Searched in Knowledge Base if a previous issue has been addressed.
