In the module SAP interface it is possible to define maintenance reports. They actually use the SAP function blocks
ALM_PM_MAINTNOT_CREATE
ALM_PM_MAINTNOT_SAVE
ALM_PM_MAINTNOT_MODIFY_DATA
These are, however, not remote enabled with a standard SAP setup. Therefor the SAP administrator would have to modify the configuration of these function blocks. Without a modification, zenon is not able to call these function blocks.
The used function bocks have been replaced. Now
BAPI_ALM_NOTIF_CREATE
BAPI_ALM_NOTIF_SAVE
BAPI_ALM_NOTIF_DATA_MODIFY
are used to create maintenance reports. These are remote enabled by default.
Issue Number: 35213
Fixed on Date: 2.12.2015
Versions: 7.60 0 BUILD 36068
