OpenDCS process library: Limit monitoring (DIntMon, AnaMon) does incorrectly trigger limits on > instead of >= (resp. < instead of <=)
The following listed OpenDCS function blocks did does incorrectly trigger limits on > instead of >= (resp. < instead of <=).
  • DIntMon V1
  • DIntMon V2
  • DIntMon V3
  • AnaMon V1
  • AnaMon V2
  • AnaMon V3
The issue has been addressed and the function block behavior is now as expected.
  • Update your OpenDCS process library for Siemens TIA and update zenon Software Platform to the latest build of zenon 15 or higher.
Item ID: 307211
Version: 15.00 Build: 518139
