Here, you can access a comprehensive list of changes across all maintained versions of the zenon Software Platform as Excel Worksheets. This includes both implemented bug-fixes and new features. Additionally, these lists are available in as Excel Files if you prefer this over CSV.
Please note that not all changes will be accompanied by descriptions immediately, as our documentation process may still be ongoing. If you are unsatisfied with the given information or specific details, please reach out to your local support team. We are committed to continuously improve the information given.
Background information for your verification process:
  1. The files are automatically generated every night.
  2. All descriptions undergo review by our documentation team.
  3. If a change item has not yet been reviewed by the documentation team, it will display "Description pending" in the description.
  4. Therefore, please be aware that descriptions may be added or modified after the initial release.
  5. If the editorial review reveals that a bug was communicated that should not have actually been communicated, such incorrect communicated items will be removed from the list.
    • Engineering Studio crash if you import csv file to the AccessIec870Sl
      Description The zenon Engineering Studio closed unexpectedly when the particular CSV file was imported to the AccessIec870Sl. The issue has been addressed and the import works now as expected. To benefit from this fix: Update your zenon Software ...
    • "Export CEL" function cuts off the Limit Value Text (by using CSV Export)
      In some cases the "Export CEL" function will cut off the Limit Value Text (by using CSV Export) by projects converted from older versions. To fix this effect you need to create a new "Export CEL" function in actual version.
    • AccessDNP3_SG: enhanced support for CSV import / CSV export
      Description [Feature]: The AccessDNP3_SG Process Gateway CSV export/import function did not support double bit binary inputs. The functional gap has been addressed and the handling of double bit binary inputs is now supported in CSV export/import ...
    • Smart Object API : Variable mapping not applied after changing in engineering studio
      Summary Changes in the variable mapping of a Smart Object instance are not applied during CSV export via SmartObject Export Wizard. This behavior has been changed. Description For a new Smart Object instance, variables are mapped in the Engineering ...
