Product changes for versions greater 7.50 of the zenon Engineering Studio & the zenon Service Engine as Excel Worksheets.
They are also availble as CSV Files.
Please note that most recent builds may not be included since changes documentation may be pending.
      Product changes for versions greater 7.50 of the zenon Engineering Studio & the zenon Service Engine in CSV Format. They are also availble as Excel Files. Please note that most recent builds may not be included since changes documentation may be ...
    • ActiveX control for zenon Runtime ends unexpectedly when inserted in a VBA form (Excel).
      Summary ActiveX control for zenon Runtime ends unexpectedly when inserted in a VBA form (Excel). DescriptionActiveX control for zenon Runtime ends unexpectedly when inserted in a VBA form (Excel). Solution Issue was addressed in license check for ...
    • FAQ: Does zenon support silent setup installation/uninstallation?
      For silent-installation and uninstallation of zenon components consult this documentation topic.
    • zenon logic: Unexpected complex data in expression
      In zenon version 8.20, it was possible to initiate and assign the function block in one line. This was not IEC compliant, therefore feature was removed in zenon 10. Now the error message "Unexpected complex data in expression" is logged when using ...
    • zenon runtime control crash under certain circumstances.
      Summary If the zenon runtime control is used in an independend form like within a VBA form in Excel, it crashes. Description If the zenon runtime control is used in an independend form like within a VBA form in Excel, it crashes. Solution This issue ...
