ArchiveVariables.Item(0) contains the trigger variable of an archive instead of the first archive variable
In version 6.51 SP0 Build 8 and before, the definition for ArchiveVariables.Item(0) was that this element should contain the first variable of the archive. From there on, it contains the trigger variable. This also applies to version 7.00 SP0.
An issue was addressed in the programming interface where the fix of another defect affected the behaviour of the ArchiveVariables collection. Now, ArchiveVariables.Item(0) contains again the first variable of an archive.
Fixed on 24.04.2012, available from 7.00 SP0 Build 1, available from 6.51 SP0 Build 13.
Issue Number: 26664
Fixed on Date: 16.4.2012
Versions: 6.51 0 BUILD 13 | 7.00 0 BUILD 1
