Driver Configuration through API: deactivating global update time has no effect
When configuring the driver through the API and setting the global update time to false, always the "normal" priority group is used, regardless what is configured at the variable.
Manually open the driver configuration in the editor and close the driver configuration with OK, makes the correct settings.
Issue Number: 140424
Fixed on Date: 25.6.2018
Versions: 7.60 0 BUILD 49005 | 8.00 0 BUILD 48821
