The IEC62056 driver should support historic values with the format OBIS*?.
The IEC62056 driver should support the OBIS*? format of historical values.
This issue has been addressed by supporting the OBIS*? address format
Issue Number: 38179
Fixed on Date: 13.4.2017
Versions: 7.60 0 BUILD 37399
    • Checklist: Printer does not print in the format as expected
      Time estimate: 15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. No .frm file is used to specify ...
    • FAQ: What is the time zone and time format used in zenon Software Platform products and what needs to be considered?
      When you ask someone what the time is, they'll usually be able to tell you. But when you ask them what date and time sunrise was yesterday in a different country on a different continent, in a different hemisphere it gets less easy. Terms like GMT ...
    • The BiffiDCM32 driver does not support the new DCM2 message format
      Summary A new DCM2 message format can be used by Emerson Biffi DCM systems that is not supported by the BiffiDCM32 driver Description A new DCM2 message format can be used by Emerson Biffi DCM systems that is not supported by the BiffiDCM32 driver ...
    • CNet driver recording incorrect values
      Description The CNetDrv driver recorded incorrect values (e.g. 0 instead of 1) because the receive buffers in the driver were not reset correctly when the connection was terminated. The issue has been addressed and the recording behavior is now as ...
    • IEC870_10332: support for private ASDUs
      Summary The IEC870_10332 driver has been extended to support private ASDUs for a specific device: ASDU 33 - switchgear position with mapping to zenon values (0 for off, 1 for on, 2 for intermediate and 3 for failure) ASDU 36 - like ASDU 4 with ...
