Checklist: Printer does not print in the format as expected
Time estimate: 15 minutes
  1. No .frm file is used to specify what is being printed and instead the default is used.
  2. Create a .frm file, or use the predefined .frm file, and insert this in the project tree under 'Texts and Formats' folder. When using offline printing of alarms, the 'alar_g.frm' file is considered. For offline printing of the event list, the 'btb_g.frm' is considered. See the help for more information on frm files, the format and which keywords are available.
  3. Use space key (blanks) to fill out the spaces between keywords as the .frm file uses tab-stops.
  4. Make sure there are sufficient blanks behind a keyword when keywords are cut-off in order to allow enough space for printing the text.
PC online printing
  1. Printer is online and contains paper.
  2. Only printers which support line-printing can be used.
  3. Printer is set to the correct character page.
With online printing, zenon sends each alarm/event immediately to the printer, in raw data form, using the font and character set in the printer.
  1. Check the number of lines for the page in the project properties.
  2. The correct format file for online printing is used: ALM - alarm.frm / CEL - btb.frm.
  3. Make sure, that at the alarm the option 'print' is activated.
  4. In project 'AML and CEL' settings group the right option for online printing is selected Alarm Message List or Chronologic Event List and 'Printing active' is enabled.
  5. Create the system driver variables for online printing and check their values in the Service Engine.
CE online printing
  1. Online printing on windows CE sends the data directly to LPT1, as there is no real printer spooler on Windows CE. Make sure the printer is connected to this interface, or the data is forwarded to another port by using a third party software.
CE offline printing
  1. Offline printing on Windows CE takes place in the foreground, blocking the whole device. The Windows CE system does not have a printer spooler, which can perform print tasks in the background.
  2. On windows CE, offline printing is always performed to the default printer of the operating system. Use e.g. wordpad, to configure which driver and which printer should be used.
  3. Not all Windows CE devices come with a printer driver. Contact the device manufacturer to ask for more information.
    • Checklist: Printer does not print
      Time estimate: 15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Printer is switched on, is online ...
    • zenon Smart Client freezes on Printer Selection
      Description In the Smart Client, opening the printer selection via the “Print with dialog” screen element in the AML or CEL screen causes the computer to freeze. This freeze can last for some time before the computer becomes operable again. The ...
    • Checklist: SAP Interface does not work
      Time estimate:  30 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Checklist usage: #. [Quick ...
    • FAQ: What is the time zone and time format used in zenon Software Platform products and what needs to be considered?
      When you ask someone what the time is, they'll usually be able to tell you. But when you ask them what date and time sunrise was yesterday in a different country on a different continent, in a different hemisphere it gets less easy. Terms like GMT ...
