Open the database containing the Certificate Authority (CA)
Create a private key
Go to the tab Private Keys and press New Key
Provide a name for the key
Press Create
Export the private key
Select the newly generated key and press Export
Provide a file name for the key
Ensure that the export format is set to PEM private
Press OK
For
security reasons, the file containing the private key shall only be
deployed to the machine running the OPC UA Process Gateway!
Create a new certificate
Go to the tab Certificates and press New Certificate
Select Use this Certificate for signing and choose your CA
Set the subject of the new certificate
Go to the tab Subject
Enter an internal name for the certificate
Provide information about your organization (not mandatory, but best practice)
Ensure to select the private key created in the previous steps
Set the extensions of the new certificate
Go to the tab Extensions
Set X509v3 Basic Constraints to:
Type: End Entity
Path length: 0
Select Critical
Set Key identifier:
Select X509v3 Subject Key Identifier
Select X509v3 Authority Key Identifier
Set validity as required
Set X509v3 Subject Alternative Name:
URI:[ApplicationUri],DNS:[FQDN]
The ApplicationUri by default is: urn:[FQDN:PORT]
In both cases, use the fully-qualified domain name (FQDN) in capital letters.
Set the key usage of the new certificate
Go to the tab Key usage
Set X509v3 Key Usage:
Select Critical
Select Digital Signature, Non Repudiation, Key Encipherment, Data Encipherment
Set X509v3 Extended Key Usage:
Select Critical
Select TLS Web Server Authentication
Press OK
Export the certificate
Select the newly generated certificate and press Export
Provide a file name for the certificate and ensure to set the file extension to .der
Ensure that the export format is set to DER
Press OK
Using the certificate in the zenon project
Add the files to the zenon project
Copy the generated files to the PKI folder of the process gateway: %CD_SYSTEM%\PKI\CA\
The private key will go into the subfolder private
The certificates of the server and the CA will go into the subfolder certs
The CRL (Certificate Revocation List) of the CA will go into the subfolder crl
Configure the zenon OPC UA Process Gateway
Switch to your zenon project and add an OPC UA Process Gateway
Setup the server parameters, variables, and archives as required
Switch to the tab Endpoints and configure security settings
Select the generated server certificate and private key
Now, any client with a valid certificate signed by the same CA is able to connect to the process gateway.
It might be required to add the newly generated server certificate, the CA certificate, and the CRL of the CA to the configuration of the OPC UA clients, too.
