Go to Drivers > New Driver
Create a Driver of Type "OPC UA Client Driver"
Open the Driver Configuration
Go to "Connections"
Create a new Connection
Enter your Discovery URL
Enter your Server URL manually or click the 3 dots to browse the Discovery URL
Optional:
Enter Username/Password and setup the certificate if you use encrypted communication.
Save everything + Close Dialog
Right click on the Driver you have just created and Select
"Read PLC Variables in Background…"
Wait trough the process, depending on the amount of datapoints, this may take a while
Right click the Driver again and select
"Import Variables from driver…"
Select the Variables/Nodes you want to import and click
"Import selected"
That’s it! Variables are now available for further use in zenon.
