Open the database containing the Certificate Authority (CA)
Create a private key
Go to the tab Private Keys and press New Key
Provide a name for the key
Press Create
Export the private key
Select the newly generated key and press Export
Provide a file name for the key
Ensure that the export format is set to PEM private
Press OK
For security reasons, the file containing the private key shall only be deployed to the machine running the OPC UA Driver!
Create a new certificate
Go to the tab Certificates and press New Certificate
Select Use this Certificate for signing and choose your CA
Set the subject of the new certificate
Go to the tab Subject
Enter an internal name for the certificate
Provide information about your organization (not mandatory, but best practice)
Ensure to select the private key created in the previous steps
Set the extensions of the new certificate
Go to the tab Extensions
Set X509v3 Basic Constraints to:
Type: End Entity
Path length: 0
Select Critical
Set Key identifier:
Select X509v3 Subject Key Identifier
Select X509v3 Authority Key Identifier
Set validity as required
Set X509v3 Subject Alternative Name:
URI:[ApplicationUri],DNS:[hostname]
The ApplicationUri by default is: urn:[hostname]
The hostname does not contain the domain part (no FQDN!)
Set the key usage of the new certificate
Go to the tab Key usage
Set X509v3 Key Usage:
Select Critical
Select Digital Signature, Non Repudiation, Key Encipherment, Data Encipherment
Set X509v3 Extended Key Usage:
Select Critical
Select TLS Web Client Authentication
Press OK
Export the certificate
Select the newly generated certificate and press Export
Provide a file name for the certificate and ensure to set the file extension to .der
Ensure that the export format is set to DER
Press OK
Using the certificate in the zenon project
Add the files to the zenon project
Switch to your zenon project and add an OPC UA Client driver
Configure the connection to the OPC UA server (without setting the certificates)
Go to the project folder Files->Drivers->PKI->CA
Add the exported private key (*.pem) to the subfolder private
Add the exported client certificate (*.der), the certificate of the CA, and the server certificate to the subfolder certs
Add the certificate revocation list (CRL) of the CA to the subfolder crl
In this example the file uaservercpp.der represents the server certificate
Configure the zenon OPC UA Driver
Finally, go back to the driver instance and open the Certificates tab in the server configuration
Select the recently imported certificates
Now, you can read the PLC variables in the background and import variables
It might be required to add the newly generated client certificate, the CA certificate, and the CRL of the CA to the configuration of the OPC UA server, too.
