API - Read DiagnosisViewer-entries into zenon Service Engine
The RequestLoggingServiceData method has been added to the IProject Interface in the Scada.AddIn.Contracts Namespace. The method allows you to read in Diagnosis Viewer LOG files with a time limit for further processing in Service Engine.
Example: A selected CEL entry provides the start time and end time for limiting the logs read in via an API event. The new method is used to request the data from the Diagnosis Viewer with a corresponding time limit. The requested LOG data can be displayed e.g. via message box in Service Engine.
Item ID: 280783
Version: 14.00 Build: 314355
    • FAQ: How can I backup the Service Engine data, the data created during Service Engine?
      The path of the Service Engine folder can be amended in the project properties and it is set into zenon6.ini (VBF30=) when the start project is set in Engineering Studio or in zenon Startup Tool. In the Service Engine folder, there is the subfolder ...
    • Checklist: The Logic Service to Service Engine connection does not work
      Time estimate:   30 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Screenshot and followed ...
