Time estimate: 30 minutes
- Logic Service to Service Engine communication worked before.
- Logic Service and Service Engine server are executed in the same computer.
- "Visible externally" is enabled in the variable "Integrated 61131-3 settings" properties in Engineering Studio. If a Logic project is defined in the property "Visible externally for:" look for syntax errors.
If no Logic project name is defined, the variable from zenon is available in all Logic projects, otherwise only in the projects specified.
Note that if a Logic project is renamed, it must be manually adapted here.
- 'Logic Service to Service Engine connection' driver is created in the Logic project in the Fieldbus configurations.
- In Logic Studio Project -> Settings... make sure:
- Cycle time is set as triggered (e.g. 10 ms).
- In Compiling options, "Keep case of embedded symbols" is enabled (Yes).
- Use recommended settings:
- In Compiling options, "Allocate status bits for variables having properties" is enabled (Yes).
- In Runtime options, "Store complex variables in a separate segment" is enabled (Yes).
- In case of a process-driven variable, the target PLC accepts write requests from zenon Service Engine server.
- "Allow external write set value" is enabled in variable "Integrated 61131-3 settings".
- The device or other Service Engine is not writing to the variable simultaneously.
- Searched and followed error instructions in LOGs related with the Service Engine (zenrt32.exe), Logic Service (STRATONRT.exe) and Logic Service to Service Engine connection fieldbus (T5BusExZenOnRT).
All zenon components write in the background messages to joint log file(s) saved in '%programdata%\COPA-DATA\LOG' folder.
- Searched in Knowledge Base if a previous issue has been addressed.
