By default, zenon Time Synchronization is enabled in all computers in zenon network. This must be disabled in redundant Network with a non-dominant server, use external time source instead.
Generally, zenon Time Synchronization shall be disabled when using an external time source (note: Windows, by default, runs a NTP-client synchronizing the clock).
For this, in [NETZ] section in zenon configuration file (zenon6.ini) (path: %CD_SYSTEM) add the line 'TIMESYNCH=0' .
The same configuration must be applied to all zenon computers in the network.
