Service Engine writes log messages in regard zenrt32.exe stability in case of errors or warnings.
You can find these entries in Diagnosis Viewer by filtering the column Function name = 'CZenonrtApp::MonitoringThread'.
Some of the most relevant performance entries are:- Memory: “Total available memory fell below warning/error level to [xxx]%”- CPU: Total CPU-Load exceeded warning/error level to [xxx]%”- Service Engine not responding for XXX ms: "100ms Timer has not cycled for [xxx]ms”- Handles: "(%) “Handles exceeded error level to [xxx]”.
In case Service Engine closes unexpectedly, zenon Drivers write in the logs "RPC error!" as they can no longer communicate with zenrt32.exe.
