WebEngine: Login does not work on Chrome 60+ on http
In general: the usage of HTTP is not recommended. Please use HTTPS.
Upon using HTTP outside the localhost network the password will now be transmitted in clear text. A notification will show up when switching to a login screen that informs the user about his/her password will be sent in clear text.
The reason is that modern browsers won't allow the usage of its crypto APIs when using HTTP: https://developer.mozilla.org/en-US/docs/Web/Security/Secure_Contexts
use https
Issue Number: 203006
Fixed on Date: 15.12.2020
Versions: 8.20 0 BUILD 79336
Checklist: HTML Web Engine
Time estimate: 20 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Screenshot and followed ...
Flashing synchronization does not work in the HTML Webengine
Summary There were two issues regarding WebEngine and flashing/blinking. There was an issue with the flashing state of elements in the WebEngine. It is expected that the flashing state of all flashing elements is the same at a given time. E.g. the ...
Keycombination Does Not Work on Login Screen When Opened via Keycombination and Authorized Function
Description The key combination did not work on a Login Screen if the screen was opened via a key combination and an authorized function. The issue has been addressed and now the key combination works on the Login Screen regardless of how it was ...
AD user login does not work in the service engine if the computer is not in the domain
Summary AD user login does not work in the service engine if the computer is not in the domain Description AD user login does not work in the service engine if the computer is not in the domain Issue Number: 248131 Fixed on Date: 19.1.2022 Versions: ...
Checklist: Smart Client does not work
