Using FTP Function Block with Windows 10, If the Inferface of the network isn't listed in 1° position doesn't work properly
When an FTP function block was used with Windows Server 16 (or higher) or Windows 10 (or higher), the Interface did not work properly if it was not listed first.
The issue has been addressed and the Interface works now as expected regardless of the position on the list.
Item ID: 290444
Version: 15.00 Build: 481184
Version: 14.00 Build: 480405
Version: 12.00 Build: 480406
