Setpoint input for Keyboard screen doesn’t work in Batch Control
In Batch Control, the setpoint input in a screen of type keyboard does not work as expected. When entering a value via a button that is linked to the function "Setpoint input for keyboard screen", the input is not executed correctly. The value is not written.
This behavior has been modified. It is now possible to enter a setpoint value in Batch Control using a button and the "Setpoint input for keyboard screen" function.
  • Update your zenon Software Platform to the latest build of zenon 8.10 or higher.
Item ID: 281452
Version: 14.00 Build: 239777
Version: 12.00 Build: 232473
Version: 11.00 Build: 231258
Version: 10.00 Build: 232665
Version: 8.20 Build: 250795
Version: 8.10 Build: 233008
    • Control Recipe import with unit placeholder doesn’t work
      Summary In Batch Control, the import of a control recipe that was previously validated without errors fails. This error has been fixed. Description In Batch Control, a control recipe with a unit placeholder is validated and exported without errors. ...
    • Control Recipe import with (and without) unit placeholder doesn’t work
      Summary In Batch Control, the import of a control recipe that was previously validated without errors fails. This error has been fixed. Description In Batch Control, a control recipe with or without a unit placeholder is validated and exported ...
    • Occasionally the value for “Setpoint input for keyboard screen“ is incorrect.
      Summary The value for “Setpoint input for keyboard screen“ is sometimes incorrect when the linear value adjustment is used at the same time. DescriptionThe value for “Setpoint input for keyboard screen“ is sometimes incorrect when the linear value ...
