When using a local Ethernet interface for Fieldbus communication in zenon Logic, you have to ensure that VLAN and/or priority settings (cf.
IEEE802.1Q) are deactivated in the network adapter configuration.
Go to the "Enhanced" page in the upcoming dialog. Depending on the network adapter, different options may appear.
Find a setting dealing with VLAN and/or priority and make
sure to deactivate those. Otherwise, you might not be able to
communicate with field devices!
If required, you can also set other options here such as manually force a specific MAC address or fix the network speed to e.g. 100 MBit.
Additionally, you should deactivate any unused protocols in the network configuration to avoid unnecessary network traffic on the fieldbus network.
Therefore, go back to the Network controller settings and only activate the following protocols:
