When changing a value manually with archive Revision which was created after the conversion to 7.20, the value is changed in the archive, in the table of the SQL database and can also be seen in the trend. When doing the same procedure with a value which was created in 7.11 (before conversion to 7.20), the value change is not recognized (Value is NOT changed in the SQL table)
enabled that NULL values in GUID colums are supported again
With this KB entry the FAQ entry 295233 is solved
