After updating to zenon 7.20 I dont see newly SQL evacuated historian data anymore in the trend (ETM), Report Generator, Report Viewer and Archive Revision, only the former evacuated values are displayed.
When having a 7.11 project and evacuating archives to SQL database, then converting project to 7.20 and start the runtime, in the ETM only the data of 7.11 is shown and the .ARX data before evacuation, but NOT the evacuated data of 7.20
adapted loading and storing SQL archive data now it works also with GUID column as CHAR, not only with VARCHAR
With this KB entry the FAQ entry 295233 is solved
Issue Number: 34058
Fixed on Date: 23.3.2015
Versions: 7.20 0 BUILD 18778
FAQ: After updating to zenon 7.20 I dont see newly SQL evacuated historian data anymore in the trend (ETM), Report Generator, Report Viewer and Archive Revision, only the former evacuated values are displayed.
Summary Solution There is an available update, see Article ID195426 / ID165155. We highly recommend to update to the linked build ID195426 If you do not update, there is a Workaround Change the GUID column of the table from CHAR to VARCHAR. With ...
FAQ: What is the difference between the zenon Report Generator and the zenon Report Viewer?
FAQ: What is the difference between the Report Viewer and the zenon Reporting Studio?
A detailed description of the differences can be found in the attached PDF documents (English and German). The description is based on zenon Supervisor 7.50 and zenon Analyzer 3.00.
