EUROMAP63: Enhancement with support for alternative communication method.
The EUROMAP63 driver has been enhanced with an alternative communication method that enables cyclic report jobs.
Variables based on the "state (shot)" driver object type are updated with a cyclic shot based report job. This is the default driver object type for imported variables. Such variables are updated only when the machine is running.
Variables based on the "state (cyclic)" driver object type are updated with a cyclic time based report job. The time interval used in the report is defined globally for the connection in the driver configuration.
The EUROMAP63
driver supports CYCLIC
TIME
communication. In the Connections tab in the configuration dialog, we added the
new option Cyclic time interval. The parameters of this option can
be set for each connection.
The new
driver object type State (cyclic) is also
available for configuration of variables. If a zenon project includes at least
one variable for this driver object type, a cycle-based report is created.
The previous
driver object type State (in previous versions)
has been renamed to State (shot).
