zenWebClientStarter duplicate start / crash while opening filter dialogues - Exception code E06D7363
If the Smart Client is started more than once on a system, the Smart Client is not running correct. A multiple start can also occur unattended if the Smart Client is started but the previously terminated instance is still active.
This behavior has been changed. Now an error message is displayed during multiple startup. Only one instance is allowed to be started.
  • Update your zenon Software Platform to the latest build of zenon 8.20 or higher.
Note: When using a terminal server, smart clients can be started multiple times.
Item ID: 252252
Version: 11.00 Build: 111398
Version: 10.00 Build: 112170
Version: 8.20 Build: 99641
    • zenWebClientStarter duplicate start / crash while opening filter dialogues - Exception code E06D7363
      Summary If zenWebClientStarter is started more than once opening variable selection dialog leads to a crash Description If zenWebClientStarter is started more than once opening variable selection dialog leads to a crash Issue Number: 252252 Fixed on ...
    • Checklist: Engineering Studio cannot start or closes unexpectedly
    • AddIn does not start - Exception displayed in Log (DiagViewer)
      In case that an AddIn (Service or Wizard) does not start and the log shows an exception message likewise equally to that below check the software development of the AddIn. Scada.Internal.DotNetAddInExtension.AddInIntegration.Startup Cannot startup ...
