zenOPCSrv: the zenon OPC DA server does not return a valid value on a SyncIO::Read from DEVICE for an active group / active item
A SyncIO::Read from DEVICE for an active item waits up to 30 seconds (starting from the time when item was activated) for a value from the zenon runtime.
Issue Number: 211551
Fixed on Date: 20.3.2020
Versions: 8.10 0 BUILD 65147
    • Checklist: OPCDA Server
    • IEC61850 Server - valKind RO (Read Only) must also be taken in account for DA with FC = SP and SE
      Description The IEC61850 Server did not refuse written values on valKind RO (Read Only) for DA with FC = SP and FC = SE. The issue has been addressed. Now the IEC61850 Server refuses written values on valKind RO (Read Only) for DA with FC = SP and FC ...
    • At redundancy switch of zenon servers, a variable with "alternative value" (ALT_VAL) suddenly gets the INVALID bit added - breaking ALC
      Description When a variable with INVALID status gets switched to "alternative value" some drivers on the active server add status ALT_VAL and remove status INVALID for this variable. After the standby server takes over the active role (redundancy ...
