zenonLogic Profinet IO driver (master) does not start when reconnecting special device
With some profinet devices (in this case phoenix Contact Interbus / Profibus Gateway) there is a problem with the reconnect of the profinet driver. The Gateway sends a mismatch of modules to point on existing diagnosis messages. But it further sends a module description that fits to the projected one. The profinet driver stops the connection when it recives a mismatch, even if it receives a module description that fits to the existing project.
The configuration is now evaluated at connection initialization. Only if the state of a module or submodule is invalid the connect attempt is trated as unsuccessful.
Fixed on 08.11.2012 with driver version 2404 available from 7.00 SP0 Build 4
Issue Number: 28905
Fixed on Date: 8.11.2012
Versions: 7.00 0 BUILD 4
