zenon Webclient stuck/doesn't synchronise if started with Internet Explorer
WebClient cannot connect to server if it is started a second time in same Internet Explorer tab.
Use "zenWebClientStarter.exe" instead of the Internet Explorer
or
Close ALL iexplore.exe processes (all Internet Explorer instances) on your Computer, before you start the zenon Webclient.
Issue Number: 189723
Fixed on Date: 25.7.2019
Versions: 8.00 0 BUILD 59775 | 8.10 0 BUILD 59911
The webclient does not start on Internet Explorer 11.
Summary The webclient cannot start in the Internet Explorer 11 since Microsoft changed the browser user agent string. Description The webclient cannot start in the Internet Explorer 11 since Microsoft changed the browser user agent string. Solution ...
Start zenon Smart Client in embedded mode using Microsoft Internet Explorer mode
This article is based on this article from Microsoft to configure Microsoft Edge to display the zenon Smart Client embedded. Add the init.htm to the Internet Explorer mode (IE mode) pages Add the zenon start page to the trusted sites in the Internet ...
Control Recipe import with unit placeholder doesn’t work
Summary In Batch Control, the import of a control recipe that was previously validated without errors fails. This error has been fixed. Description In Batch Control, a control recipe with a unit placeholder is validated and exported without errors. ...
Setpoint input for Keyboard screen doesn’t work in Batch Control
Description In Batch Control, the setpoint input in a screen of type keyboard does not work as expected. When entering a value via a button that is linked to the function "Setpoint input for keyboard screen", the input is not executed correctly. The ...
