zenon to PAS-X MES connectivity solution
Bidirectional exchange of data between Werum PAS-X and zenon
The Werum MSI Interface enables the bidirectional exchange of data between Werum PAS-X and zenon. Werum PAS-X can thus use zenon to directly access the production machines and process data.
The interface is configured using the Werum MSI Configuration Tool.
Item ID: 237856
Version: 11.00 Build: 157700
    • Engineering Studio: Add Driver 'Siemens : S7 driver for S7-1200/1500' to Zenon Project - Error when starting driver
      Summary The S7TIA/S7 for S7-1200/1500 driver cannot be started. This issue has been solved. Description The attempt to add the driver S7TIA/S7 for S7-1200/1500 to a project fails in some constellations with an error message (Error code 0x8001011f). ...
    • zenon embedded Metadatabase editors (with Active X)
      Summary The solution consists of 2 points: 1) zenon has been extended by calling the garbage collector on closing screens. 2) The Manual Data Editor and the Metadata Editor are modified to dual controls (windows forms and Active X). Description The ...
    • Password change at first user logon works via operating system but not via zenon SE ; no AD login possible
      Description In the Edge Gateway frontend, the user password can no longer be changed in MS Active Directory, when the zenon system is not a member of the domain. Despite correctly entering the previous password and the new password including password ...
