zenon stops working when using Scheduler in compatibility mode
In a network setup where the server uses an older zenon version (7.10 and older) than a client (e.g. 7.60) then the Server may stop working when it tries to open the Scheduler screen after a schedule has been created on the client.
The client Runtime didn´t correctly handle the older schedule format.
After the fix, a client identifies the version of the server and stores the schedules accordingly.
None
Issue Number: 155653
Fixed on Date: 2.11.2018
Versions: 7.20 0 BUILD 53457 | 8.00 0 BUILD 53129 | 7.50 0 BUILD 54309 | 7.60 0 BUILD 52515 | 7.11 0 BUILD 58691
    • zenon crashes using Scheduler in Compatibility Mode
      Description When using the Scheduler, the Service Engine (Runtime) crashes in compatibility mode. For example, Service Engine files are created in version 7.60 for 7.11. The server is started in version 7.11, the client in version 7.60. If an entry ...
    • Scheduler in compatibility mode isnt working
      Description Creating schedules does not work in compatibility mode. For example, Service Engine files (Runtime files) are created in version 7.60 for 6.22 SP1. The server is started in version 6.22 SP1, and the client is started in version 7.60. If ...
    • straton stops working when executing frequent redundancy switches
      Description zenon Logic stops working unexpectedly in version 12 in redundancy mode in case of frequent server switches. This error has been fixed. Redundancy mode works as expected again. To benefit from this fix: Update your zenon Software Platform ...
