On specific system constellation – Windows 10 Build 1511 and/or 1607 - it could be that the zenon setup cancel with ‘Service, CodeMeter Runtime Server failed to start. Verify that you have sufficient privileges to start system services.’
An issue was addressed at the CodeMeter services on specific system constellation.
Workaround for 7.50 -> install CodeMeter version high then 6.40.
zenon 7.60 setup will be including automatically an higher version of the CodeMeter services.
Workaround:
Install the latest CodeMeter Runtime version for example: 6.40.2396.500, which can be downloaded from Wibu System directly, before installing zenon 7.50.
Issue Number: 37491
Fixed on Date: 15.12.2016
Versions: 7.60 0 BUILD 36068
