zenon runtime control crash under certain circumstances.
If the zenon runtime control is used in an independend form like within a VBA form in Excel, it crashes.
This issue has been addressed and the zenon runtime control does not crash anymore.
Issue Number: 35138
Fixed on Date: 25.9.2015
Versions: 7.11 0 BUILD 22586
    • Some scenario with JSON functions crashes the runtime
      Description zenon Logic is terminated unexpectedly under certain circumstances. This happens when the "JsonWriteTxb" block is used. This error has been fixed. The implementation of the "JsonWriteTxb" block has been adapted. This block can now be used ...
    • Engineering Studio: Add Driver 'Siemens : S7 driver for S7-1200/1500' to Zenon Project - Error when starting driver
      Summary The S7TIA/S7 for S7-1200/1500 driver cannot be started. This issue has been solved. Description The attempt to add the driver S7TIA/S7 for S7-1200/1500 to a project fails in some constellations with an error message (Error code 0x8001011f). ...
    • ETM: Runtime is crashing under certain circumstances when using curve property for auxiliary lines
      Summary ETM: Runtime is crashing under certain circumstances when using curve property for auxiliary lines Description ETM: Runtime is crashing under certain circumstances when using curve property for auxiliary lines Issue Number: 244749 Fixed on ...
