zenon Runtime closes unexpectedly, when executing the function "trend comparison lot"
Under specific circumstance the zenon Runtime closes unexpectedly, when executing the function " trend compare lot " was executed.
An issue was addressed at the zenon Runtime where the 2nd time selection lot Filter in extended trend diagram function caused an error. It should not be possible to combine 2nd time period and relative lot selection. Now the zenon Runtime no longer closes with an error message and the extended trend is printed correctly through the function.
That added a lot filter page.
Issue Number: 35925
Fixed on Date: 12.5.2016
Versions: 7.20 0 BUILD 26116 | 7.60 0 BUILD 36068
