zenon Runtime closes unexpectedly, when executing from Report Viewer the function "print" with an invalid printer configuration
In addition if you have no '.RDL' file linked and you open the Report Viewer screen and press the Print button the RT will closes unexpectedly.
An issue was addressed at the zenon Runtime where the printer have invalid configuration. Now the zenon Runtime no longer closes. Zenon have new specific error messages and don't print if invalid printer or settings not valid "setup not accepted".
Issue Number: 31850
Fixed on Date: 12.5.2016
Versions: 7.50 0 BUILD 28116
    • Checklist: Printer does not print
      Time estimate: 15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Printer is switched on, is online ...
    • FAQ: What is the difference between the Report Viewer and the zenon Reporting Studio?
      A detailed description of the differences can be found in the attached PDF documents (English and German). The description is based on zenon Supervisor 7.50 and zenon Analyzer 3.00.
    • Output window: "Report Viewer: export/print" function provides incorrect warning in the output window
      Summary The "Report viewer: export/print" function issues incorrect warnings in the output window. This has been fixed. Description Under certain conditions, the "Report viewer: export/print" function issues incorrect warnings in the output window. ...
