zenon Runtime closes unexpectedly, if between Report Generator profiles is switched too fast
With too fast switching (via screen switch function) between Report Generator profiles Runtime stopped unexpectedly.
During the loading of a profile no new profile is allowed to be loaded. Therefor the Profile-ComboBox will now be disabled as soon as a profile is selected, and will be enabled again as soon as the profile-request has been handled/finished.
Issue Number: 34941
Fixed on Date: 24.6.2016
Versions: 7.20 0 BUILD 30230 | 7.60 0 BUILD 36068
FAQ: What is the difference between the zenon Report Generator and the zenon Report Viewer?
Report Generator: Service Engine closes when changing the applied filter very quickly
Description When quickly switching between several profiles of the Report Generator filter, the Service Engine terminates with an error message. This is caused by repeated calls of a profile. To fix the problem: Update your zenon 10 or 11 to build ...
zenon Logic Runtime closes unexpectedly when starting a specific application
Summary zenon Logic Runtime no longer closes unexpectedly when it is configured an high amount of Report Control Blocks in the IEC 61850 Server + GOOSE fieldbus driver. Description zenon Logic Runtime no longer closes unexpectedly when it is ...
