zenon Runtime – multi monitor system, behaves differently dependent of the used operation system.
If using a multi monitor system for example with 2 monitor or a constellation of 2x2 monitors in combination with Windows 8, 8.1 or 10, it could be that the second screen cannot be displayed as expected. The behaviour is not reproducible with Windows 7.
An issue was addressed to specific changes of the operation system since Windows 8. Now, the multi monitor configuration is working as expected for 2 or across a 2x2 constellation.
Issue Number: 35861
Fixed on Date: 17.5.2016
Versions: 7.20 0 BUILD 28103 | 7.50 0 BUILD 28986
    • Multi-touch: "Windows 8 and later" recognition behaves differently in hard and Smart client
      Description Operation with Multi-Touch for Windows 8 and higher leads to different results in the native Service Engine and in the Smart Client. Cause: To compensate for a misbehavior of Windows, the handling of Multi-Touch in the Smart Client was ...
    • FAQ: How can I create a Performance Monitor Log file?
      Windows Performance Monitor can be used and configured to record in the background Windows processes' performance counters and Operating System resources usage on the long run. Windows Performance Monitor logs are useful when troubleshooting system ...
    • Checklist: Multimonitor administration
      Time estimate:  15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. zenon configuration file ...
