zenon Process Gateway ICCP sends zenon and not ICCP name variables
Now uses configured ICCP name on communication level.
A possible workarround was to use the ICCP Name as the zenon name for the variables.
Issue Number: 31017
Fixed on Date: 13.12.2013
Versions: 7.10 0 BUILD 9356
Checklist: Process Gateway cannot establish a reliable communication
Checklist: Process Gateway cannot start
While type mismatches zenon Process Gateway ICCP-TASE.2 as client on data set reception is corrupting value of not mismatched variables
Summary zenon Process Gateway ICCP TASE.2 is mismatching received values - all (or some) of zenon variables linked in ICCP-client. It transfers to the Runtime values of another received data points or random. It happens only when by one (or more) ...
