zenon Logic with IEC60870 Slave causes the device to stop responding under specific circumstances.
When the zenon Logic runtime is running a project with an iec870 slave, the device may stop responding after some time.
A sporadic issue has been addressed in the T5Bus870Slave bus driver for the zenon Logic where under specific circumstances the Logic RT could enter an endless loop, blocking the system. Now the zenon Logic with 870 slave no longer shows this behaviour.
Issue Number: 28518
Fixed on Date: 13.2.2013
Versions: 7.00 0 BUILD 7
    • FAQ: Where can I find the XML device profile for COPA-DATA DNP3 drivers?
      What is a DNP3 XML device profile? Where can I find the XML device profile for one of the following drivers? DNP3_TG - Subset Level 1,2,3 and 4 for both requests and responses, DNP3 Master driver for zenon Service Engine AccessDNP3_SG - Subset Level ...
    • Project in zenon Logic takes long time to compile and eventually Stops responding.
      Description A zenon Logic project takes a very long time to compile and may even stop responding. This can also affect the Engineering Studio. This mainly occurs when UDFBs are shared across several projects. This error has been fixed. Compiling a ...
    • zenon runtime may stop responding under specific circumstances when using .WMF graphics
      Summary When using .wmf graphics in combi elements, the runtime may sporadically stop responding on opening a screen that displays such .wmf graphics. DescriptionWhen using .wmf graphics in combi elements, the runtime may sporadically stop responding ...
