zenon Logic shows unexpected behaviour after several redundancy switches.
After several redundancy switches, the zenon Logic runtime shows unexpected behaviour.
This issue has been addressed by not accessing the winthread member from other threads.
Issue Number: 38682
Fixed on Date: 20.7.2017
Versions: 7.50 0 BUILD 39729
straton stops working when executing frequent redundancy switches
Description zenon Logic stops working unexpectedly in version 12 in redundancy mode in case of frequent server switches. This error has been fixed. Redundancy mode works as expected again. To benefit from this fix: Update your zenon Software Platform ...
zenon logic: Unexpected complex data in expression
In zenon version 8.20, it was possible to initiate and assign the function block in one line. This was not IEC compliant, therefore feature was removed in zenon 10. Now the error message "Unexpected complex data in expression" is logged when using ...
Project in zenon Logic takes long time to compile and eventually Stops responding.
Description A zenon Logic project takes a very long time to compile and may even stop responding. This can also affect the Engineering Studio. This mainly occurs when UDFBs are shared across several projects. This error has been fixed. Compiling a ...
