zenon logic runtime supports online change with c-compiled code
The zenon logic runtime now also supports online change when c-compiled runtime code is used
The zenon logic workbench and the zenon logic runtime have been enhanced to also support online change with the zenon logic runtime when using c-compiled code
Issue Number: 26422
Fixed on Date: 13.3.2012
Versions: 7.00 0 BUILD 0
    • EIP Scanner: Performing Online change in zenon Logic causes the EIP communication to break
      Description In zenon Logic the Ethernet/IP Adapter aborts the communication when online changes are performed in the Ethernet/IP Scanner. The communication cannot be restored. This error has been fixed. If the connection is interrupted, it is ...
    • zenon logic runtime crash with C-compiled logic code
      Description After compiling the project in the Engineering Studio and starting the Service Engine the Logic Service crashed when it is started. The issue has been fixed and the behavior is now as expected. To benefit from this fix: Update your zenon ...
    • Zenon Logic: OEM specific blocks and functions are marked as not supported after coverting a project from zenon 12 to zenon 14
      Description When converting from zenon 12 to zenon 14, OEM specific functions and blocks for zenon Logic are marked as "not supported". This is due to a name change in the "Select" tab of the "Target System Configuration" dialog. "Logic Runtime for ...
