zenon logic runtime does not start on a CE panel if a variable with profile IEC60870S is created
Project with IEC60870S driver in Fielbus configuration using serial port for communication. Errormessage in output window: Opening bus driver 'T5Bus870Slave' for cold resp. warm start failed.
Serial port was not opened. This has been corrected.
Issue Number: 30960
Fixed on Date: 4.12.2013
Versions: 7.10 0 BUILD 9356 | 7.11 0 BUILD 10238
    • Checklist: Update CE fails
      Time estimate:   15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Screenshot and followed ...
    • FAQ: Update CE proceedure
    • The zenon Logic runtime does not start on a specific touch panel computer.
      Summary The zenon Logic runtime does not start in the TPC-31T panel running on a Windows CE 6.0 operating system. Description The zenon Logic runtime does not start in the TPC-31T panel running on a Windows CE 6.0 operating system. Solution An issue ...
    • FAQ: Windows CE not supported anymore with zenon! What are the main reasons and what do I have to consider? Is zenon not able to run on Windows CE anymore?
      The support for zenon Windows CE Versions was frozen with the zenon Version of 7.20. This means that in any higher zenon version, the CE Version delivered with the Setup is a zenon CE Version of zenon 7.20. There are no more functional enhancements ...
