Zenon Logic: OEM specific blocks and functions are marked as not supported after coverting a project from zenon 12 to zenon 14
When converting from zenon 12 to zenon 14, OEM specific functions and blocks for zenon Logic are marked as "not supported". This is due to a name change in the "Select" tab of the "Target System Configuration" dialog. "Logic Runtime for Windows" has been renamed to "Logic service for Windows". During the conversion, the configuration in zenon 14 is therefore set to "Default" instead of "Logic service for Windows".
This behavior has been modified. The configuration is now applied correctly.
Note: The configuration can also be adjusted manually without updating the zenon version. To do this, set the configuration to "Logic service for Windows" in the "Target System Configuration" dialog
Item ID: 281575
Version: 14.00 Build: 239777
