zenon Logic MODBUS master sporadically looses connection to the slave device.
zenon Logic MODBUS master sporadically closes and reopens the TCP Port connection to the slave device.
An issue has been addressed in the zenon Logic MODBUS master which caused a sporadic loss of connection to the slave device due to receiving an unexpected amount of data.
Issue Number: 34705
Fixed on Date: 30.6.2015
Versions: 7.10 0 BUILD 21022 | 7.20 0 BUILD 21629
FAQ: Where can I find the XML device profile for COPA-DATA DNP3 drivers?
What is a DNP3 XML device profile? Where can I find the XML device profile for one of the following drivers? DNP3_TG - Subset Level 1,2,3 and 4 for both requests and responses, DNP3 Master driver for zenon Service Engine AccessDNP3_SG - Subset Level ...
zenon logic stops if mobus slave connects to modbus master over serial
Summary zenon logic crashes if mobus slave connects to modbus master over serial. Written error message "Application STRATONRT.exe encounted a serious error and must shut down" Description zenon logic crashes if mobus slave connects to modbus master ...
zenon Logic with IEC60870 Slave causes the device to stop responding under specific circumstances.
Summary When the zenon Logic runtime is running a project with an iec870 slave, the device may stop responding after some time. Description When the zenon Logic runtime is running a project with an iec870 slave, the device may stop responding after ...
