zenon Logic - Import using XMLMERGE of K5B.exe stucks with certain XML
When importing a zenon Logic XML file with XMLMERGE via K5B.exe the import does not finish; the process hangs in an endless loop. When using workarounds, the import seems to finish successfully, but not all elements are imported. But the manual import within the zenon Engineering Studio works without problems.
This behavior has been changed. The import now works successfully.
Tip: To see new data types after an import with XMLMERGE, the project must be reloaded.
Item ID: 260900
Version: 11.00 Build: 117823
    • FAQ: I would like to create XML Import files manually outside from zenon. Is there a schema definition to validate such XML files?
      For the zenon XML Formats there are actually no style definitions available or documented. We recommend to use an exported file (e.g. from the Engineering Studio) as a basis for the manipulation. That's the best way to ensure a proper format of the ...
    • K5B.exe - XMLMERGE deactivates ALL struct-sub-variables
      Description Sub-variables of structure data type variables can be activated or deactivated in zenon Engineering Studio. When executing the zenon Logic add-on program K5B.exe with the command line option XMLMERGE, all already activated structure data ...
    • zenon logic: Unexpected complex data in expression
      In zenon version 8.20, it was possible to initiate and assign the function block in one line. This was not IEC compliant, therefore feature was removed in zenon 10. Now the error message "Unexpected complex data in expression" is logged when using ...
    • Checklist: Configuring the FTP Function Block in Zenon Logic
      FTP Connection Parameters: IPServer: The IP address of the FTP server. IPClient: The IP address of the computer where the data will be transferred. UserName: The username for accessing the FTP server. Password: The password for accessing the FTP ...
