TCP Listener port of the zenon Logic I/O driver 'IEC61850 Server' is fix 102 (as defined in the Standard). Thus you can run only one instance per PC. To easy demonstrate that zenon iec850 driver (Client) is able to communicate to a large number of IEDs, we need zenon Logic to simulate many IEDs -> several instances per PC are required.
added driver configuration setting - IP Port; default 102.
Issue Number: 36091
Fixed on Date: 16.3.2016
Versions: 7.50 0 BUILD 27465
