zenon Logic FTP function block gives incorrect information if server cannot be reached
when the IPSERVER parameter is not correct the FB gives the feedback that the connection is open.
Problem was addressed in the STATs feedback handling. Changed STATs to correct states in the requiired situations
Issue Number: 33911
Fixed on Date: 9.3.2015
Versions: 7.11 0 BUILD 18678
Checklist: Configuring the FTP Function Block in Zenon Logic
FTP Connection Parameters: IPServer: The IP address of the FTP server. IPClient: The IP address of the computer where the data will be transferred. UserName: The username for accessing the FTP server. Password: The password for accessing the FTP ...
The zenon logic FTP function block does not send files if their names contain 5XX (e. g. 500,510,501).
Summary The zenon logic FTP function block does not send files with the PUT command if the file names contain 5XX (e. g. 500,510,501). As a result the FTP server creates a file with that name but with size of 0KB. The function block gives back the ...
zenon logic: Unexpected complex data in expression
In zenon version 8.20, it was possible to initiate and assign the function block in one line. This was not IEC compliant, therefore feature was removed in zenon 10. Now the error message "Unexpected complex data in expression" is logged when using ...
