zenon Logic: Ethernet/IP Adapter and Ethernet/IP Scanner will not be started in Logic Service
In zenon Logic ServiceEthernet/IP Adapter and Ethernet/IP Scanner are not started,
although they were configured correctly in Logic Studio. When starting the Logic Service
they are not started as expected. Diagnosis Viewer logs indicate that
components needed for execution are not found.
This error has been fixed. Ethernet/IP scanner
and Ethernet/IP adapter are started correctly again in the Logic Service.
higher.
Item ID: 268675
Version: 12.00 Build: 162090
New Ethernet/IP Scanner block to restart specific IO connection
Logic Service fieldbus "Ethernet/IP Scanner" driver allows to restart IO connection of a specific EIP adapter (IP address) using the block EIPRESTARTCNX. The EIPRESTARTCNX block is available since zenon 10 build 138660. Refer to product documentation ...
EIP Scanner: Performing Online change in zenon Logic causes the EIP communication to break
Description In zenon Logic the Ethernet/IP Adapter aborts the communication when online changes are performed in the Ethernet/IP Scanner. The communication cannot be restored. This error has been fixed. If the connection is interrupted, it is ...
T5BusEIPS: EtherNet/IP Adapter does not make use of TCP Keep Alive
Description The EtherNet/IP Adapter (T5BusEIPS) does not make use of TCP keep alive messages to check if the TCP connection from an EtherNet/IP Scanner is still OK. The issue has been addressed and the T5BusEIPS enables a TCP keep alive for the ...
