Zenon logic crash - Astrazenca Project
Unexpected Logic Service crash when using shared memory. This has been fixed.
If data types are incorrectly advised during the exchange between Service Engine and Logic Service via shared memory - for example Numeric variables on String variables - this led to a crash.
This crash is now prevented. However, data types must still not be mixed.
Recommendation: Make sure you use the correct data types when advising.
Item ID: 267865
Version: 12.00 Build: 162090
    • Project in zenon Logic takes long time to compile and eventually Stops responding.
      Description A zenon Logic project takes a very long time to compile and may even stop responding. This can also affect the Engineering Studio. This mainly occurs when UDFBs are shared across several projects. This error has been fixed. Compiling a ...
    • Distributed Engineering: Changes in zenon Logic project cause all Services to be checked out
      Description In the Distributed Engineering since zenon version 14 all services had to be checked out to make changes on an existing zenon logic project. The issue has been addressed and a check-out is not required anymore. To benefit from this fix: ...
