zenon logic: 1 gain FB with LD can't assign a structure to a structure
In zenon Logic it was not possible to add a structure to a structure in LD. However, this is possible in ST and FDB. As a workaround, you can activate the "LD optimizations" option in the project settings in LD.
This behavior has been modified. Adding structures to a structure is now also possible in LD.
Item ID: 280574
Version: 14.00 Build: 239777
Version: 12.00 Build: 232473
Version: 11.00 Build: 231258
Version: 10.00 Build: 232665
    • LD: confusion between FB input and global variable
      Summary In zenon Logic, the global variable is used instead of the local parameter in certain constellations in the Ladder Diagram (LD). This has been fixed. Description In zenon Logic, a user-defined function block has an input parameter. This has ...
    • Compiler crashes when parsing a LD program
      Description zenon Logic is terminated unexpectedly when building an LD program. The cause is the handover of a two-dimensional array to a UDFB that expects a one-dimensional array as input. This cannot work and leads to an error. It is expected that ...
    • zenon logic: Unexpected complex data in expression
      In zenon version 8.20, it was possible to initiate and assign the function block in one line. This was not IEC compliant, therefore feature was removed in zenon 10. Now the error message "Unexpected complex data in expression" is logged when using ...
